Rotate Euler Node
../../../_images/modeling_geometry-nodes_utilities_rotate-euler_node.png
The Rotate Euler node.
The Rotate Euler node rotates an Euler rotation.
Ingressi
Rotazione
The Euler rotation to rotate.
Rotate By
Specifies how much an Euler rotation is rotated. This input is only available when the rotation type is set to Euler.
Asse
The axis to rotate around. This input is only available when the rotation type is set to Axis Angle.
Angolo
The angle to rotate by around the specified axis. This input is only available when the rotation type is set to Axis Angle.
Proprietà
Rotation Type
Axis Angle
Use separate axis and angle inputs to control the rotation.
Euler
Use an Euler input to control the rotation.
Space
Oggetto
Rotate an Euler rotation in the evaluated object’s space.
Locale
Rotate an Euler rotation in local space.
Uscite
Rotazione
The rotated Euler rotation.
