Mesh Boolean Node
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
../../../_images/modeling_geometry-nodes_mesh_boolean_node.png
The Mesh Boolean node.
Inputs
Mesh 1/2
Entrada padrão de geometria.
Self Intersection
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Hole Tolerant
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Properties
Operação
Intersecção
Produz uma nova geometria contendo apenas o volume dentro de tanto a geometria 1 e geometria 2.
União
The two input meshes are joined, then any interior elements are removed.
Diferença
Geometria 2 é subtraída da geometria 1 (tudo fora da geometria 2 é mantido).
Saída
Mesh
Saída padrão de geometria.
