Split Edges Node
../../../_images/modeling_geometry-nodes_mesh_split-edges_node.png
The Split Edges node.
Like the Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking “links” between faces around those split edges.
Inputs
Mesh
Entrada padrão de geometria.
Seleção
A standard Boolean selection input to determine which edges will be split.
Nota
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Properties
Saídas
Mesh
Saída padrão de geometria.
