Set Shade Smooth Node
../../../_images/modeling_geometry-nodes_mesh_set-shade-smooth_node.png
The Set Shade Smooth node.
The Set Shade Smooth node controls whether the mesh’s faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
Inputs
Mesh
Entrada padrão de geometria.
Shade Smooth
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
Seleção
Boolean input for selecting which faces will have the Shade Smooth value applied.
Properties
Saídas
Mesh
Saída padrão de geometria.
