Mesh to Points Node
../../../_images/modeling_geometry-nodes_mesh_mesh-to-points_node.png
Mesh to Points node.
The Mesh to Points node generates a point cloud from a mesh.
Inputs
Mesh
Standard Mesh input.
Seleção
The meshes used to generate a point cloud.
Posição
Positions of generated points. By default, this input is the same as if the Position Node was connected.
Raio
Radii of generated points.
Properties
Mode
Vértices
Points are generated for each vertex.
Arestas
Points are generated for each edge, at the middle of each edge, by default.
Faces
Points are generated for each face, at the average of all of each face’s vertices, by default.
Laterais
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Saídas
Pontos
Generated point cloud.
