Edge Neighbors Node
Edge Neighbors Node.
The Edge Neighbors node outputs topology information relating to each edge of a mesh.
Inputs
Este nó não possui conectores de entrada.
Properties
Saídas
Face Count
The number of faces that use the edge as one of their sides. When the value is one, the edge is a non-manifold boundary edge. Alternatively, when the value is zero, the edge is a loose edge, not used by any faces.
Examples
../../../_images/modeling_geometry-nodes_input_edge-vertices_boundary.png
Using the Face Count output to create a curve on a mesh’s boundary edges.
