Convex Hull Node
![Convex Hull node.](../../../_images/node-types_GeometryNodeConvexHull.webp)
The Convex Hull node outputs a convex mesh that is enclosing all points in the input geometry.
Примітка
When the node is used on a geometry with instances, the algorithm will run once per instance, resulting in many convex hull meshes in the instance geometries. The Realize Instances node can be used to get a convex hull of an entire geometry.
Важливо
Volumes are not supported by this node, and attributes are not automatically transferred to the result.
Inputs – Уводи
- Geometry – Геометрія
Standard geometry inputs.
Properties – Властивості
This node has not properties.
Outputs – Виводи
- Опукла Оболонка – Convex Hull
Mesh that encloses all points in the input.
