Delete Geometry Node
Delete Geometry node.
The Delete Geometry node removes the selected part of a geometry. It behaves similarly to the Delete tool in Edit Mode. The type of elements to be deleted can be specified with the domain and mode properties.
Inputs – Уводи
Geometry – Геометрія
Standard geometry input.
Selection – Вибрання
Boolean field that is true for parts of the geometry to be deleted.
Properties – Властивості
Домен – Domain
The domain on which the selection field is evaluated.
Вказування – Point
The selection is on the points, control points, and vertices of the geometry.
Edge – Край
The selection is on the edges of the mesh component. The other components are not modified.
Faces – Грані
The selection is on the faces of the mesh component. The other components are not modified.
Сплайн – Spline
The selection is on the splines in the curve component. For each spline, it will either be deleted entirely or not at all. The other components are not modified.
Примірники
The selection is on the top-level instances, and the entire instance is removed if it is selected. If the input also contains realized geometry, that will be unaffected.
Mode – Режим
The type of elements to be affected. This only applies to the mesh component.
All – Усе
Vertices, edges, and faces in the selection will be deleted.
Лише Ребра і Грані – Only Edges & Faces
Vertices won’t be deleted, even if they are in the selection.
Лише Грані – Only Faces
Only faces in the selection will be deleted.
Вивід – Output
Standard geometry output.
