Geometry Input Node
Geometry Input node.
The Geometry Input node provides geometry from an external object, collection, or input connection to be used inside a node group. It is useful for referencing other geometry data or injecting custom geometry into a procedural setup.
Inputs – Уводи
Geometry – Геометрія
The geometry input to the node group, used when the node is connected to another geometry socket.
Input Type
Determines the source type of the geometry.
Object – Об’єкт:
Uses a single object as the geometry source.
Collections – Колекції:
Uses all objects within a collection as the geometry source.
Object / Collection
Specifies the object or collection to use as the geometry input, depending on the selected Input Type.
Relative Space
When enabled, the input geometry is transformed relative to the modifier or main geometry’s local space, rather than using its original world-space transform.
As Instance
When enabled, the geometry is added as an instance instead of being merged into the main geometry. Some operations require realized (non-instance) geometry, so use this option accordingly.
Замінити Оригінал – Replace Original
  • When enabled, the incoming geometry is replaced by the selected input geometry.
  • When disabled, the input geometry is added alongside the existing one.
Outputs – Виводи
The resulting geometry from the selected object, collection, or input connection.
