Set Instance Transform Node¶
The Set Instance Transform node Transforms geometry instances using a Transformation Matrix.
The Примірники page contains more information about geometry instances.
Inputs – Уводи¶
- Примірники
Standard geometry input.
- Selection – Вибрання
Boolean field used to determine if an instance will be rotated.
- Transform – Трансформа
The transformation matrix to translate, rotate, and scale individual instances.
Outputs – Виводи¶
- Примірники
Standard geometry output.
