Randomize Transforms Node
Randomize Transforms node.
The Randomize Transforms node applies random translation, rotation, and scale to instances. It is commonly used to create natural variation among duplicated objects, such as scattered rocks, trees, or other elements in a scene.
Inputs – Уводи
Примірники
The input geometry containing the instances to be randomized.
Selection – Вибрання
Controls which instances are affected by the randomization. Only selected instances will receive random transformations.
Local Space – Локальний Простір
  • When enabled, transformations are applied in each instance’s local coordinate space.
  • When disabled, randomization is performed in the global coordinate space.
Offset – Зсув
The maximum translation offset for each axis. Defines the random range for instance movement.
Rotation – Обертання
The maximum rotation for each axis. Defines how much each instance can be rotated.
Scale Axes
Determines how scaling is applied.
Uniform – Рівномірно:
Applies a single random scale factor uniformly to all axes.
Axes – Осі:
Applies an independent random scale factor to each axis.
Scale – Масштаб
The maximum scaling factor applied to each instance.
Flipping
Randomly flips instances along one or more axes, effectively mirroring them.
Базис – Seed
An integer value that initializes the random number generator. Changing the seed produces a different random arrangement while keeping the same parameters.
Outputs – Виводи
Примірники
The resulting geometry with randomized instance transforms applied.
