Attribute Proximity
../../../_images/modeling_geometry-nodes_attribute_attribute-proximity_node.png
The Attribute Proximity node.
For each point in the input geometry, this node finds the closest position on the target. Both the positions and the distances to them can be stored in attributes.
Inputs
Geometria
Entrada padrão de geometria.
Target
Distância
The name of the float attribute where the computed distance is stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Posição
The name of the attribute where the computed location is stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Properties
Target Geometry
Faces
Calculate the closest point anywhere on the faces of the target geometry’s mesh.
Arestas
Calculate the closest point anywhere on the edges of the target geometry’s mesh.
Pontos
Calculate the closest point or vertex on the target geometry. This mode is usually the fastest.
Saída
Geometria
Saída padrão de geometria.
Examples
The different modes of the node: faces, edges and points. In this example the geometry nodes modifier is added on the plane. Note that the plane is subdivided and the cube is not.
../../../_images/modeling_geometry-nodes_attribute_attribute-proximity_faces.png
Target Geometry mode: faces.
../../../_images/modeling_geometry-nodes_attribute_attribute-proximity_edges.png
Target Geometry mode: edges.
../../../_images/modeling_geometry-nodes_attribute_attribute-proximity_points.png
Target Geometry mode: points.
Be sure to set the mode to points when the target is a point cloud.
../../../_images/modeling_geometry-nodes_attribute_attribute-proximity_pointcloud-target.png
Attribute Proximity node with a point cloud as target.
