Attribute Remove
../../../_images/modeling_geometry-nodes_attribute_attribute-remove_node.png
The Attribute Remove node.
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
Inputs
Geometria
Entrada padrão de geometria.
Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don’t exist can’t be removed.
Properties
Saída
Geometria
Saída padrão de geometria.
