Введение в оконную систему¶
After starting Blender and closing the Splash Screen the Blender window should look something similar to the image below; as Blender’s user interface is consistent across all platforms.
Окно запуска Blender по умолчанию.¶
Интерфейс Blender разделён на три основные части:
Topbar at the very top.
Areas in the middle.
Status Bar at the bottom.
Макет экрана Blender по умолчанию. Верхняя панель инструментов (синий цвет), Области (зелёный) и Строка состояния (красный).¶
Customization¶
Blender also makes heavy use of keyboard shortcuts to speed up work. These can also be customized in the Keymap Editor.
Цветовая тема
Blender allows for most of its interface color settings to be changed to suit the needs of the user. If you find that the colors you see on screen do not match those mentioned in the Manual then it could be that your default theme has been altered. Creating a new theme or selecting/altering a pre-existing one can be done by selecting the Preferences editor and clicking on the Themes tab.
