Bounding Box (габаритный контейнер)¶
The Bounding Box node.¶
The Bounding Box node creates a cube with the minimum volume that encapsulates the geometry of the input. The node also can output the vector positions of the bounding dimensions.
Входы¶
- Geometry (геометрия)
Стандартный вход геометрии.
Свойства¶
Этот узел не содержит свойств.
Выходы¶
The resulting box or cube to encapsulate the input geometry.
- Min
The coordinates corresponding to the cubes -X, -Y, -Z position values, i.e. how far the box extends in each of the negative axes directions.
- Max
The coordinates corresponding to the cubes +X, +Y, +Z position values. i.e. how far the box extends in each of the positive axes directions.
