Nút Đường Cong Vectơ -- Vector Curves Node¶
Vector Curves Node.¶
The Vector Curves node maps an input vector components to a curve.
Use this curve node to slow things down or speed them up from the original scene.
Đầu Vào -- Inputs¶
In the shader context the node also has an additional Factor property.
- Hệ Số -- Factor
Controls the amount of influence the node exerts on the output vector.
- Vectơ -- Vector
Đầu vào vectơ tiêu chuẩn.
Tính Chất -- Properties¶
- Kênh -- Channel
X, Y, Z
- Đường Cong -- Curve
For the curve controls see: Curve widget.
Đầu Ra -- Outputs¶
- Vectơ -- Vector
Standard vector output.
