Sample Nearest Surface Node
Sample Nearest Surface node.
The Sample Nearest Surface node finds values at the closest points on the surface of a source mesh geometry. Non-face attributes are interpolated across the surface.
This node is similar to the 几何节点, but it gives the value of any attribute at the closest surface point, not just its position.
Warning
Because the node samples the surface of a mesh rather than its edges or vertices, values from loose points and edges are ignored.
输入
网格
要检索属性的几何图形。
数值
用于与传输方法一起使用的 几何体上的求值字段。
Sample Position
The position to start from when finding the closest location on the target mesh. By default, this is the same as if the 位置节点 was connected.
属性
数据类型
The data type to use for the retrieved values.
输出
数值
The data retrieved and interpolated from the Source geometry, mapped based on the node's settings and inputs.
