Attribute Statistic Node
../../../_images/modeling_geometry-nodes_attribute_attribute-statistic_node.png
The Attribute Statistic node.
The Attribute Statistic node evaluates a field on a geometry and outputs a statistic about the entire data set.
輸入
Geometry
Standard geometry input.
Attribute
The attribute field to query a statistic from.
屬性
Data Type
Float
The output will be a single floating-point value.
Vector
The output will be a vector of three floating-point values. All calculations are elementwise.
Domain
Spline
Data is queried from each spline.
Face Corner
Data is queried from each face corner.
Corner
Edge
Data is queried from each edge.
Point
Data is queried from each point.
輸出
Mean
The average value of all data.
Median
The median value of all data.
Sum
The sum value of all data.
Min
The min value of all data.
Max
The max value of all data.
Range
The difference between the max and min value.
Standard Deviation
How much values differ from the mean. A low standard deviation indicates that the values are grouped tightly together at the mean. A high standard deviation indicates that the values are spread out over a large range.
Variance
The variance of all data, defined as the square of the standard deviation.
