Attribute Statistic Node
The Attribute Statistic node.
The Attribute Statistic node evaluates a field on a geometry and outputs a statistic about the entire data set.
Inputs – Уводи
- Геометрія – Geometry
Standard geometry input.
- Атрибут – Attribute
The attribute field to query a statistic from.
Властивості – Properties
- Тип Даних – Data Type
- Float
The output will be a single floating-point value.
- Vector – Вектор
The output will be a vector of three floating-point values. All calculations are elementwise.
- Домен – Domain
- Сплайн – Spline
Data is queried from each spline.
- Face Corner
Data is queried from each face corner.
- Куток – Corner
- Edge – Край
Data is queried from each edge.
- Вказування – Point
Data is queried from each point.
Outputs – Виводи
- Mean – Середнє
The average value of all data.
- Median – Серединне
The median value of all data.
- Sum
The sum value of all data.
- Min – Мін
The min value of all data.
- Max – Макс
The max value of all data.
- Range – Діапазон
The difference between the max and min value.
- Standard Deviation – Стандартне Відхилення
How much values differ from the mean. A low standard deviation indicates that the values are grouped tightly together at the mean. A high standard deviation indicates that the values are spread out over a large range.
- Variance
The variance of all data, defined as the square of the standard deviation.
