Scale Elements Node
![Scale Elements node.](../../../_images/node-types_GeometryNodeScaleElements.webp)
The Scale Elements Node scales groups of connected edges and faces. When multiple selected faces/edges share the same vertices, they are scaled together. The center and scaling factor is averaged in this case.
Inputs – Уводи
- Mesh – Сіть
Standard geometry input.
- Selection – Вибрання
Whether to scale each edge or face. True values mean the element will be scaled, false means it will be unaffected.
- Scale – Масштаб
The factor used to scale elements or groups of elements.
- Center – Центр
Origin of the scaling for each element. If multiple elements are connected, their center is averaged.
- Direction Single Axis Mode Only
Direction in which to scale the element. This input is normalized internally, so the length does not matter.
Properties – Властивості
- Домен – Domain
The element type to transform.
- Face – Обличчя
Scale individual faces or neighboring face islands.
- Edge – Край
Scale individual edges or neighboring edge islands.
- Scale Mode – Режим Масштабу
- Uniform – Рівномірно
Scale elements by the same factor in every direction.
- Single Axis – Одинична Вісь
Scale elements in a single direction defined by the Direction input.
Вивід – Output
- Mesh – Сіть
Standard geometry output.
Examples – Приклади
![../../../_images/modeling_geometry-nodes_flip-faces_extrude.png](../../../_images/modeling_geometry-nodes_flip-faces_extrude.png)
The node is useful when combined with the Extrude Mesh Node, especially in Individual mode, where face islands don’t need to be scaled together.
