Split Edges Node
![Split Edges node.](../../../_images/node-types_GeometryNodeSplitEdges.webp)
Like the Модифікатор «Розділ Ребром» – Edge Split Modifier, the Split Edges node splits and duplicates edges within a mesh, breaking „links“ between faces around those split edges.
Inputs – Уводи
- Mesh – Сіть
Standard geometry input.
- Selection – Вибрання
A standard Boolean selection input to determine which edges will be split.
Примітка
Because of mesh topology requirements, sometimes more or fewer edges than are selected will be split.
Properties – Властивості
Outputs – Виводи
- Mesh – Сіть
Standard geometry output.
