Set Shade Smooth Node
![Set Shade Smooth node.](../../../_images/node-types_GeometryNodeSetShadeSmooth.webp)
The Set Shade Smooth node controls whether the mesh’s faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
Inputs – Уводи
- Mesh – Сіть
Standard geometry input.
- Згладжене Відтінення – Shade Smooth
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
- Selection – Вибрання
Boolean input for selecting which faces will have the Shade Smooth value applied.
Properties – Властивості
Outputs – Виводи
- Mesh – Сіть
Standard geometry output.
