Nút Thông Tin Vật Thể -- Object Info Node¶
Object Info Node.¶
The Object Info node gives information about the object instance. This can be useful to give some variation to a single material assigned to multiple instances, either manually controlled through the object index, based on the object location, or randomized for each instance. For example a Noise texture can give random colors or a Color Ramp can give a range of colors to be randomly picked from.
Đầu Vào -- Inputs¶
Nút này không có đầu vào.
Tính Chất -- Properties¶
Đầu Ra -- Outputs¶
- Vị Trí -- Location
Location of the object in world space.
- Color
Object color, same as Color in the .
- Chỉ Số Vật Thể -- Object Index
Object pass index, same as Pass Index in the .
- Chỉ Số Nguyên Liệu -- Material Index
Material pass index, same as Pass Index in the .
- Ngẫu Nhiên -- Random
Random number unique to a single object instance.
Ghi chú
Note that this node only works for material shading nodes; it does nothing for light and world shading nodes.
