Attribute Curve Map Node
Warning
This node is considered legacy and will be removed in Blender 4.0.
Please use the Float Curve instead.
The Attribute Curve Map node.
The Attribute Curve Map node maps an attribute to a new attribute based on a curve.
输入
- 几何数据(Geometry)
Standard geometry input.
- 属性
Source attribute name.
- 结果
Result attribute name.
属性
- 数据类型
Determines as which type the source attribute is interpreted. This also changes how many curves can be modified below.
- 曲线
For the curve controls see: Curve widget.
输出
- 几何数据(Geometry)
Standard geometry output.
