Attribute Remove Node
Warning
This node is considered legacy and will be removed in Blender 4.0.
../../../_images/modeling_geometry-nodes_attribute_attribute-remove_node.png
The Attribute Remove node.
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
输入
几何数据(Geometry)
Standard geometry input.
Attribute (Multi-Input)
The name of the attribute to remove. Multiple attributes can be removed at once by connecting multiple String Input nodes. Built-in and nonexistent attributes cannot be removed.
属性
这个节点没有属性。
输出
几何数据(Geometry)
Standard geometry output.
