Attribute Transfer Node
../../../_images/modeling_geometry-nodes_attribute_attribute-transfer_node.png
Attribute Transfer node.
The Attribute Transfer node transfers an attribute from one geometry to another.
输入
几何数据(Geometry)
Geometry to transfer the attribute to.
Source Geometry
Geometry to transfer the attribute from.
Name of the attribute on the source geometry.
目标
Name of the attribute on the destination geometry.
属性
Domain that the attribute is transferred to. For example, it is possible to transfer a point attribute from one geometry to the face domain of another geometry. In Auto mode, the node tries to guess the domain based on what domain the attribute belongs to.
映射
How elements from the destination geometry are mapped to points on the source geometry.
最近的面插值
Transfer the attribute from the nearest point on the surface. Non-face attributes are interpolated across the surface (edge attributes are not supported yet). Loose points and edges are ignored.
最近
Transfer the attribute from the nearest element. No interpolation is done.
输出
几何数据(Geometry)
Standard geometry output.
