Attribute Sample Texture Node
Warning
This node is considered legacy and will be removed in Blender 4.0.
The Attribute Sample Texture node evaluates a texture for every point and
stores the resulting colors in a new attribute.
The mapping attribute can be anything that can be converted to a 3D vector.
Typically, either the name of a UV map or the position
attribute is used.
Note
UV maps can only be accessed after a Point Distribute node currently. This is a limitation that will be resolved.
An Attribute Sample Texture node can be added quickly by dragging a texture data-block into the node editor.
输入
- 几何数据(Geometry)
Standard geometry input.
- 纹理
The texture the node should sample colors from.
- 映射
Name of the attribute that determines where the texture is evaluated.
- 结果
Name of the attribute where the results are stored.
属性
这个节点没有属性。
输出
- 几何数据(Geometry)
Standard geometry output.
