Attribute Fill Node
../../../_images/modeling_geometry-nodes_attribute_attribute-fill_node.png
The Attribute Fill node.
The Attribute Fill node sets the value for every element of the attribute with the input name to the input value.
输入
几何数据(Geometry)
Standard geometry input.
属性
The name of the attribute to fill with the value. If the attribute doesn't exist yet, it will be created.
明度
A value of the data type to fill the attribute with.
属性
Domain of the output attribute.
自动
Chooses the domain of the attribute if it exists already, otherwise it uses the point domain.
点光
Store the resulting attribute per point.
Store the resulting attribute per edge.
Store the resulting attribute per face.
面拐
Store the resulting attribute per face corner.
数据类型
The type of data to fill the attribute with.
输出
几何数据(Geometry)
Standard geometry output.
