Attribute Separate XYZ Node
Warning
This node is considered legacy and will be removed in Blender 4.0.
Please use the Separate XYZ Node instead.
The Attribute Separate XYZ Node splits a vector into its individual components.
输入
- 几何数据(Geometry)
Standard geometry input.
- 矢量
The vector to split into components. This can be an attribute name or a vector.
- Result X, Result Y, Result Z
The names of the attributes to store the components of the input vector. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
属性
- 类型
- 属性
The input is a text field that expects an attribute name.
- 矢量
The input is a vector of three float numbers.
输出
- 几何数据(Geometry)
Standard geometry output.
