Nodo Información de imagen
El nodo Información de imagen.
The Image Info node outputs spatial and transformation information about an image in the compositor.
This node is useful for generating procedural effects that depend on image size or position. It enables workflows such as vignette creation using math nodes, or dynamic scaling of effects relative to image dimensions.
Entradas
Imagen
The image to retrieve information from.
Propiedades
Este nodo no contiene propiedades.
Salidas
Dimensiones
The dimensions of the image in pixels with transformations applied.
Resolución
El ancho y el alto de la imagen en píxeles.
Posición
The position of the image in compositing space.
Rotación
The rotation of the image in radians, around its center.
Escala
The scale of the image relative to its original size in compositing space.
