Attribute Clamp¶
The Attribute Clamp node.¶
This node inputs one attribute and clamps the values and writes these to the result attribute.
Entrées¶
- Geometry
Entrée géométrie standard.
- Attribute
Name of the attribute that is to be clamped.
- Result
Name of the attribute where the computed result it stored. If an attribute with this name does not exist yet, a new attribute is added. If it does exist, the values of the attribute are overridden.
- Min
Minimum value. This socket changes according to data type selected.
- Max
Maximum value. This socket changes according to data type selected.
Propriétés¶
- Data Type
This determines the data type of the result attribute. This also changes the Min and Max inputs to match the data type.
- Operation
This determines how the data is clamped.
- Min Max
Constrain value between min and max.
- Range
Constrain value between min and max, swapping inputs when min is greater than max.
Sortie¶
- Geometry
Sortie de géométrie standard.
