Attribute Remove¶
The Attribute Remove node.¶
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
Entrées¶
- Geometry
Entrée géométrie standard.
- Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don’t exist can’t be removed.
Propriétés¶
Ce nœud n’a pas de propriétés.
Sortie¶
- Geometry
Sortie de géométrie standard.
