Set Instance Transform Node¶
The Set Instance Transform node Transforms geometry instances using a Transformation Matrix.
The Instances page contains more information about geometry instances.
Inputs¶
- Instances
Entrada padrão de geometria.
- Seleção
Boolean field used to determine if an instance will be rotated.
- Transform
The transformation matrix to translate, rotate, and scale individual instances.
Propriedades¶
Saídas¶
- Instances
Saída padrão de geometria.
