Translate Instances Node¶
![Translate Instances node.](../../../_images/node-types_GeometryNodeTranslateInstances.webp)
The Translate Instances node moves top-level geometry instances in local or global space.
The Instances page contains more information about geometry instances.
Inputs¶
- Instances
Entrada padrão de geometria.
- Seleção
Boolean field used to determine if an instance will be translated.
- Translation
The vector to translate the instances by.
- Local Space
If enabled, the instances are translated relative to their initial rotation. Otherwise they are translated in the local space of the modifier object.
Properties¶
Saídas¶
- Instances
Saída padrão de geometria.
