Store Named Attribute Node
![Store Named Attribute node.](../../../_images/node-types_GeometryNodeStoreNamedAttribute.png)
The Store Named Attribute node stores the result of a field on a geometry as an attribute with the specified name. If the attribute already exists, the data type and domain will be updated to the values chosen in the node. However, keep in mind that the domain and data type of Встроенные атрибуты cannot be changed.
Compared with the Узел Capture Attribute, this node basically does the same thing, but the attribute gets a name instead of an anonymous reference. For reusing the data in the same node tree, the Capture Attribute node might be preferrable since it does not create the chance for name conflicts in the input geometry.
Примечание
If the input geometry contains multiple geometry component types, the attribute will be created on each component that has the chosen domain.
Входы
- Geometry (геометрия)
Стандартный вход геометрии.
- Value
The input field to evaluate.
- Name (имя)
The name to give the stored data.
Свойства
- Тип данных
- Domain
Which attribute domain to store the evaluated data on.
Выходы
Стандартный выход геометрии.
- Attribute
Результат оценённого поля, сохранённый в геометрии.
