Separate Geometry Node
The Separate Geometry node.
The Separate Geometry node produces two geometry outputs. Based on the Selection input, the input geometry is split between the two outputs.
Порада
This node can be combined with the Compare Floats node for a more precise control of which parts are separated to a given output geometry.
Inputs – Уводи
- Геометрія – Geometry
Standard Geometry input.
- Selection – Вибрання
Boolean field used to calculate which output each part of the geometry will go to. Parts in the selection will move to the Selection output. Parts not in the selection will move to the Inverted output.
Властивості – Properties
- Домен – Domain
The domain on which the selection field is evaluated.
- Вказування – Point
The selection is on the points, control points, and vertices of the geometry.
- Edge – Край
The selection is on the edges of the mesh component. The other components are not modified.
- Faces – Грані
The selection is on the faces of the mesh component. The other components are not modified.
- Сплайн – Spline
The selection is on the splines in the curve component. For each spline, it is either entirely in the selection or not at all. The other components are not modified.
Примітка
When selecting a domain that doesn’t modify all components, the unmodified components will appear in both outputs.
Outputs – Виводи
The parts of the geometry in the selection.
- Inverted
The parts of the geometry not in the selection.
