Compare Floats Node
../../../_images/modeling_geometry-nodes_utilities_float-compare_node.png
Compare Floats Node.
The Compare Floats node takes two inputs and does a math comparison between them.
Inputs – Уводи
A, B
Standard float value input.
Epsilon – Епсилон
This value is used as a threshold for still considering the two inputs as equal for the Equal and Not Equal operations.
Властивості – Properties
Режим – Mode
Less Than – Менше Ніж
True if A is smaller than B.
Less than or Equal
True if A is smaller or equal to B.
Greater Than – Більше Ніж
True if A is bigger than B.
Greater than or Equal
True if A is bigger or equal to B.
Equal
True if A and B are the same.
Not Equal
True if A and B are different.
Вивід – Output
Результат
Standard Boolean output.
