Mesh Boolean Node
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
The Mesh Boolean node.
Inputs – Уводи
- Mesh 1/2
Standard geometry input.
- Self Intersection
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
- Hole Tolerant
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
Властивості – Properties
- Operation – Операція
- Перетин – Intersect
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
- Об’єднання – Union
The two input meshes are joined, then any interior elements are removed.
- Різниця – Difference
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Вивід – Output
- Mesh – Сіть
Standard geometry output.
