Mesh to Points Node
../../../_images/modeling_geometry-nodes_mesh_mesh-to-points_node.png
Mesh to Points node.
The Mesh to Points node generates a point cloud from a mesh.
Inputs – Уводи
Mesh – Сіть
Standard Mesh input.
Selection – Вибрання
The meshes used to generate a point cloud.
Position – Позиція
Positions of generated points. By default, this input is the same as if the Position Node was connected.
Radius – Радіус
Radii of generated points.
Властивості – Properties
Режим – Mode
Vertices – Вершини
Points are generated for each vertex.
Edges – Краї
Points are generated for each edge, at the middle of each edge, by default.
Faces – Грані
Points are generated for each face, at the average of all of each face’s vertices, by default.
Corners – Кутки
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
Outputs – Виводи
Points – Точки
Generated point cloud.
