Attribute Clamp¶
The Attribute Clamp node.¶
This node inputs one attribute and clamps the values and writes these to the result attribute.
输入¶
- 几何数据(Geometry)
标准的几何图形输入。
- 属性
Name of the attribute that is to be clamped.
- 结果
Name of the attribute where the computed result it stored. If an attribute with this name does not exist yet, a new attribute is added. If it does exist, the values of the attribute are overridden.
- 最小值
Minimum value. This socket changes according to data type selected.
- 最大值
Maximum value. This socket changes according to data type selected.
属性¶
- 数据类型
This determines the data type of the result attribute. This also changes the Min and Max inputs to match the data type.
- 操作
This determines how the data is clamped.
- 最小/最大
Constrain value between min and max.
- 范围
Constrain value between min and max, swapping inputs when min is greater than max.
输出¶
- 几何数据(Geometry)
标准的几何体输出。
