Attribute Separate XYZ¶
The Attribute Separate XYZ Node splits a vector into its individual components.
输入¶
- 几何数据(Geometry)
标准的几何图形输入。
- 矢量
The vector to split into components. This can be an attribute name or a vector.
- Result X, Result Y, Result Z
The names of the attributes to store the components of the input vector. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
属性¶
- 类型
- 属性
The input is a text field that expects an attribute name.
- 矢量
The input is a vector of three float numbers.
输出¶
- 几何数据(Geometry)
标准的几何体输出。
