Attribute Remove¶
The Attribute Remove node.¶
The Attribute Remove node removes a number of given attributes from each element of the given Geometry.
输入¶
- 几何数据(Geometry)
标准的几何图形输入。
- Attribute (Multi-Input)
The name of the attribute to remove. Multiple attribute can be removed at once by connecting multiple String Input nodes. Built-in attributes and attributes that don't exist can't be removed.
属性¶
这个节点没有属性。
输出¶
- 几何数据(Geometry)
标准的几何体输出。
