Attribute Randomize¶
Attribute Randomize Node.¶
The Attribute Randomize node replaces the values in an attribute with random values within the given range.
输入¶
- 几何数据(Geometry)
标准的几何图形输入。
- 属性
Name of the attribute to fill with random values. If there is no attribute with the given name, a new one is created.
- 最小值
The random value will be at least those values.
- 最大值
The random values will be no more than those values.
- 种子
Seed to change the random sequence.
属性¶
- 类型
Type of data stored in the attribute.
- 浮动
Single (floating-point) value.
- 矢量
Array of three (floating-point) values.
- 布尔
A true or false value.
- 操作
How new random attribute values relate to the existing attribute values.
- Replace/Create
Replace the value and data type of an existing attribute, or create a new one.
- 相加
Add the random values to the existing attribute values.
- 相减
Subtract random values from the existing attribute values.
- 正片叠底(相乘)
Multiply the existing attribute values with the random values.
输出¶
- 几何数据(Geometry)
标准的几何体输出。
