Is Shade Smooth Node
../../../_images/modeling_geometry-nodes_input_is-shade-smooth_node.png
Is Shade Smooth Node.
The Is Shade Smooth node outputs true for each face of the mesh if that face is marked to render smooth shaded. Otherwise, if the face is marked to render as flat shaded, so the node outputs false.
輸入
This node has no inputs.
屬性
這個節點沒有屬性。
輸出
Smooth
Boolean value that indicates whether the normals of each face corner on the final mesh are smoothed with normal of all adjacent faces or not.
