Mesh to Points Node
../../../_images/modeling_geometry-nodes_mesh_mesh-to-points_node.png
Mesh to Points node.
The Mesh to Points node generates a point cloud from a mesh.
輸入
Mesh
Standard Mesh input.
Selection
The meshes used to generate a point cloud.
Position
Positions of generated points. By default, this input is the same as if the Position Node was connected.
Radius
Radii of generated points.
屬性
Mode
Vertices
Points are generated for each vertex.
Edges
Points are generated for each edge, at the middle of each edge, by default.
Faces
Points are generated for each face, at the average of all of each face's vertices, by default.
Corners
Points are generated for each corner. The points are all placed at the location of each corners vertex, so they will overlap by default.
輸出
Points
Generated point cloud.
