Mesh Boolean Node
The Mesh Boolean Node allows you to cut, subtract, and join the geometry of two inputs. This node offers the same operations as the Boolean modifier.
../../../_images/modeling_geometry-nodes_mesh_boolean_node.png
The Mesh Boolean node.
輸入
Mesh 1/2
Standard geometry input.
Self Intersection
Correctly calculates cases when one or both operands have self-intersections. This involves more calculations making the node slower.
Hole Tolerant
Optimizes the Boolean output for Non-manifold geometry at the cost of increased computational time. Because of the performance impact, this option should only be enabled when the solver demonstrates errors with non-manifold geometry.
屬性
Operation
Intersect
Produce a new geometry containing only the volume inside of both geometry 1 and geometry 2.
Union
The two input meshes are joined, then any interior elements are removed.
Difference
Geometry 2 is subtracted from geometry 1 (everything outside of geometry 2 is kept).
Output
Mesh
Standard geometry output.
