Set Shade Smooth Node
The Set Shade Smooth node.
The Set Shade Smooth node controls whether the mesh's faces look smooth in the viewport and renders. The input node for this data is the Is Shade Smooth node.
輸入
- Mesh
Standard geometry input.
- Shade Smooth
When true, the selected faces will be marked to render smooth shaded. Otherwise the faces will be rendered flat shaded.
- Selection
Boolean input for selecting which faces will have the Shade Smooth value applied.
屬性
這個節點沒有屬性。
輸出
- Mesh
Standard geometry output.
