Instance Scale Node#
The Instance Scale outputs the size of top-level instances on each axis in the local space of the modifier object.
The Instances page contains more information about geometry instances.
Inputs#
This node has no inputs.
Properti#
This node has no properties.
Outputs#
- Scale
Vector that indicates the scale of each top-level instance.
