Translate Instances Node#
The Translate Instances node moves top-level geometry instances in local or global space.
The Instances page contains more information about geometry instances.
Inputs#
- Instances
Standard geometry input.
- Selection
Boolean field used to determine if an instance will be translated.
- Translation
The vector to translate the instances by.
- Local Space
If enabled, the instances are translated relative to their initial rotation. Otherwise they are translated in the local space of the modifier object.
Properti#
This node has no properties.
Outputs#
- Instances
Standard geometry output.
