Attribute Combine XYZ¶
Attribute Combine XYZ Node.¶
The Attribute Combine XYZ Node combines a vector attribute from individual components.
Входы¶
- Geometry (геометрия)
Стандартный вход геометрии.
- X, Y, Z
The inputs to the components of the vector.
- Result (результат)
The name of the attribute where the computed vector is stored. A new attribute with that name is added if it does not exist yet. If it does exist, the values of the existing attribute are overridden.
Примечание
The resulting vector is not normalized.
Свойства¶
- X, Y, Z
- Attribute
The input is a text field that expects an attribute name.
- Float
The input is a float number.
Output (выход)¶
Стандартный выход геометрии.
